Multy X ap isolation
kopite
Hiya,
I got my multy X yesterday and have been getting it all set up.
When trying to connect my Google home minis and Chromecasts though I get a message telling me to disable ap isolation but I can't find how to do this in the app.
Any ideas?
#MultyX_January
Any ideas?
#MultyX_January
Hi kopite,I cannot find the setting about AP isolation in Multy X app, but it seems disable AP isolation as default. My devices are connected to Multy X and they can communicate each other. (I have a Chromecast Gen. 1 without the problem.)
FW of Multy X: V1.00(ABKJ.3)C0Android APP of Multy X: V1.4.1.171227Topology: Internet---<WAN>Router<LAN>---<WAN>1st Multy X)))<WLAN>(((2nd Multy X)))<WLAN>(((All devices- What's generation of your Chromecast?- Is your control device (Install Google Home app) and Chromecast both connect to "Private network" of Multy X? (Not Guest WiFi)- Can you share your network topology?0
FW of Multy X: V1.00(ABKJ.3)C0Android APP of Multy X: V1.4.1.171227Topology: Internet---<WAN>Router<LAN>---<WAN>1st Multy X)))<WLAN>(((2nd Multy X)))<WLAN>(((All devices- What's generation of your Chromecast?- Is your control device (Install Google Home app) and Chromecast both connect to "Private network" of Multy X? (Not Guest WiFi)- Can you share your network topology?0 -
This was a weird one. When I first added the devices it said about ap isolation but the next day they all just worked.
All works now then
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
