Fan/system error, room to cold?
DLH007
i have a NAS520 in my cellar, it has about 16 degrees.
It shuts down every saturday morning at 4:30 with internal schedule that i have setup.
This works for months, but since a few weeks it dont work anymore.
The NAS stays in an unreachable status. The System LED is blinking endless and no reaction via http/ssh or telnet, fan is running.
I can ping the NAS, thats all.
After manual power down and power on it works again, but it gives a message saying fan error. if i look at system status, the fan rpm is N/A, afer maybe 30sec the fand works with about 230 rpm and all is fine.
i think the fan stops because system has 16 degress and the system thinks this is a error?
it has work all days in summer.
thanks for help.
#NAS_January
thanks for help.
#NAS_January
Thanks Mijzelf, maybe i try this.I have another NAS (Synology), if the NAS520 continue to have trouble with low temps within the specs, i will sell it. Never had issues with the Zyxel in my living room. If it cant be a simple backup NAS for my Synology or only in summer, it has to go.0
16 degrees in Celcius or Fahrenheit?
The specifications say:So 16 degrees celcius should be no problem, it's almost in the midst of the range. But 16 degrees fahrenheit is out of spec.Operating Environment
- Temperature: 0°C to 40°C (32°F to 104°F)
- Humidity: 10% to 95% (Non-condensing)
Storage Environment
- Temperature: -30°C to 70°C (-22°F to 158°F)
the fan was running normal as the error occur
i mean, 16 degree celsius
As Mijzelf mentioned, 16 degree celsius should be no problem.But the fan speed 230 rpm is very slow... I check my device and the fan speed is over 900 rpm..For your reference.0
Yes i know 230 rpm is very low, but the cellar is cold enough. at the moment i have the nas in my living room for inspecting. here the fan runs between 800 and 900 rpm.maybe the fan controller lower the rpm/voltage under such a tiny value the fan cant spin anymore.0
It is possible to force a minimal rpm, I have written about that here. Problem is that you can only inject that code if the box is already booted. So if it doesn't bootup you can't use this. But it is possible that it boots, and then shuts down if it detects the fan isn't running. In that case it is usable.0
- 238 Nebula Ideas
- 6.8K Security
- 753 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
