Is Multy X able to connect IP phones or DECT?
Tauchloewe
Is Multy X able to connect to IP phones or DECT Phones? or do I need an additional "box"?
#MultyX_January
#MultyX_January
Hi Tauchloewe,To my knowledge, Multy X is supported SIP pass through.About DECT, what is your infrastructure?
May I know how do you connect DECT with Multy X? Do you encounter the problem about IP phones or DECT phones?0 -
Hi, today I got 2 Siemens gigaset connected direkt to my Fritzbox. As I would like to use the old fritzbox more and more only as a modem question was if it is possible to connect the phones to the Multy0
What kind of your 2 Siemens gigaset? Model name?0
its just 2 gigaset A320 Handhelds0
I cannot find the manual from Gigaset about A320.But I think if you want to connect the telephone with Multy X.The telephone need to support Ethernet or wireless connection.For example,
Gigaset A510 IP base has Ethernet port for connecting to Internet via the router (LAN).I hope it's helpful.0 -
Thanks!!!0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
