New firmware for power schedule bug?
@Kew,
The FW for the 326 is not compatible with 540, if you test, the install failed, you have to wait an update.
I switch all my installation to another product/vendor, I never comme back here in the futur.
@Zyxel_Admin : Is it possible for you to completly delete my zyxelcloud account please ?0 -
@Fredzoul1
We are really sad to hear that you will be leaving Zyxel.
Can you pm me your e-mail account for myzyxelcloud, then I will check internal and let you know the result via private message.
Sincere thank you for your great support for Zyxel NAS in the forum.
BRs,
Brian.
Same problem (one of many) with NAS3260
Hi all. Have the same problem - power on/off scheduling (new nas326) does not work at all. Even after upgrade to latest firmware. Any solution available? Thanks for answers.
Hallo I have the same problem - power on / off scheduling in my new ZyXEL NAS326 does not work at all. Even after upgrading firmware. Looking forward for a solution!BRsBG Nordic0
Hello Brian, I 've a NAS540 with fw5.21(AATB.1) where the wake on lan doesn't work anymore.Do you have any solution (perhaps via private message)?!Thanks in advance, BRs LSt0
Hi @LStThe function tested is workable, and here is the similar case from other article as yours, can you refer it and check if the function would be disable?Thanks.BRs,Brian.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
