New firmware for power schedule bug?
13
  • Kew
    Kew Posts: 3 image  Freshman Member
    Fredzoul1 I am use NAS540 and the firmware I've received is for NAS326. Since I didnt mentioned in my earlier message. So I will have to wait for their answer if I can use the same firmware.
  • Fredzoul1
    Fredzoul1 Posts: 97 image  Ally Member
    @Kew,
    The FW for the 326 is not compatible with 540, if you test, the install failed, you have to wait an update.
    I switch all my installation to another product/vendor, I never comme back here in the futur.
    @Zyxel_Admin : Is it possible for you to completly delete my zyxelcloud account please ?
  • Zyxel_Brian
    Zyxel_Brian Posts: 41 image  Zyxel Employee
    @Fredzoul1
    We are really sad to hear that you will be leaving Zyxel.
    Can you pm me your e-mail account for myzyxelcloud, then I will check internal and let you know the result via private message.
    Sincere thank you for your great support for Zyxel NAS in the forum.
    BRs,
    Brian.
  • LukaszS
    LukaszS Posts: 5 image  Freshman Member
    Same problem (one of many) with NAS326
  • Zyxel_Brian
    Hi @LukaszS
    Already sent you the private message.
    Please check your message box.
    BRs,
    Brian.
  • RediWi55
    RediWi55 Posts: 1 image  Freshman Member
    Hi all. Have the same problem - power on/off scheduling (new nas326) does not work at all. Even after upgrade to latest firmware. Any solution available? Thanks for answers.
  • Zyxel_Brian
    Hi @RediWi55
    BRs,
    Brian.
  • BGNordic
    BGNordic Posts: 1 image  Freshman Member
    Hallo I have the same problem - power on / off scheduling in my new ZyXEL NAS326 does not work at all. Even after upgrading firmware. Looking forward for a solution!
    BRs
    BG Nordic
  • LSt
    LSt Posts: 2 image  Freshman Member
    Hello Brian, I 've a NAS540 with fw5.21(AATB.1) where the wake on lan doesn't work anymore.
    Do you have any solution (perhaps via private message)?!
    Thanks in advance, BRs LSt
  • Zyxel_Brian
    edited October 2018
    Hi @LSt
    The function tested is workable, and here is the similar case from other article as yours, can you refer it and check if the function would be disable?
    Thanks.
    BRs,
    Brian.
