Reset nsa310
HarryK64
HarryK64 Posts: 3 image  Freshman Member
edited February 2018 in Personal Cloud Storage
How can I overwrite firmware on the nsa310 with a usb pin that is installed universal_usb_key_func-2015-10-12.zip on it, it has been used for TDC backup disk. I would like zyxel firmware installed on it, I have reset it on the button, with a paper clip and after number two beep I take it away and there are 3 beeps, I enter 192.168.1.5 in my browser, but I can not get in contact nsa310. I have a network cable connected between the computer and the nsa310. can you help me? Best regards Erik
#NAS_February
  • Batou
    Batou Posts: 101 image  Ally Member
    Do you want to change use from TDC to Zyxel official version?
    If yes, that I recommand you to ask TDC for the way to do it.
  • HarryK64
    Yes, I want to, and have contacted TDC so waiting for answers. where do i find usb_key_func.sh.telnet two usb_key_func.sh.2 that can be used with software for a usb pin to get in touch with nsa310
  • HarryK64
    no help from TDC, so I hope there is someone here who can help me access nsa310
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
  • Alexey2008
    Alexey2008 Posts: 3 image  Freshman Member
    Greetings! I bought the NSA310 TDC. I want to install the standard firmware NSA310. Links nas-central.org do not work. I can not find the files force_flash.zip or TDC_to_OBD.zip anywhere. Help me please.
