Multy X to be compatible with Homekit/Siri/homepod?
Lomprayah
Do you mean that you want to use HomePod to control Multy X?Such as turn on/off Multy X LED, turn off guest Multy X WiFi, ... via voice?
BTW, when Homekit and HomePod are connecting the same WiFi network in your home, it will work properly.Set up and use HomePod: https://support.apple.com/en-us/HT208241
May I know do you encounter the problem?0 -
Hi, but i have not seen anywere that Multy X is compatible with Siri/homekit?, only with Alexa0
Multy X works with Amazon Alexa, it means you use voice to control Multy X via Amazon Alexa.Please refer to user guide page 37.But you still can use HomePod to do what it can do except use voice to control Multy X.0
Hi
What can i then use Homepod/Siri to do with Multy X?
Anders0 -
Currently, Multy X does not support through HomePod to control it.Thanks for your feature request in Multy X and we will evaluate it.And I have moved this post to Ideas Discussions.0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
