Show private or guest network under parental control in App
Lomprayah
Lomprayah Posts: 24  Freshman Member
Third Anniversary
edited March 2018 in Multy WiFi System
Hi
Is it possible to have which network (private or guest) the different devices are connected to under parental control in App, if not can this be added ?
#MultyX_March
  • ENDLESS
    ENDLESS Posts: 56  Ally Member
    You can go to "Settings" to check which client is connected to Guest WiFi.
    When the device is connected to Guest WiFi, the IP address would be 192.168.141.X.
  • Zyxel_Steven
    Zyxel_Steven Posts: 246  Zyxel Employee
    edited March 2018
    Thanks for your feature request in Multy X.
    We will evaluate this feature request and add it to wish list. :)
