NSA-220plus full reset/factory reset
DaSoul
I just plugged in my old NAS and wanted to set it up from scratch. I logged in via the web interface but couldn't find anything to fully reset the entire NAS. So i tried to delete the existing volume which is currently set to JBOD, but I want to run it as Raid 1.
If I click on delete the progress bar takes some minutes to go to 98%, but then doesn't move any further. I even let it run overnight but this doesn't help.
If I refresh the browser the NAS isn't accessible anymore, I have to turn it off and on again to be able to access the web interface again.
Any advice?
Thanks.
#NAS_March
Any advice?
Thanks.
#NAS_March
Have you tried hardware reset?
And you can refer the NSA220-Plus user guide on page 25 for reset button:
ftp://ftp2.zyxel.com/NSA-220_Plus/user_guide/NSA-220 Plus_3.1_Ed1.pdf
Thanks for your reply.
As you can see from your screenshot:
"The reset process does NOT affect the volume settings, nor data stored on the NSA"
So this won't help.
Actually in none of the guides i found anything related to a volume reset.
I don't think my drives are damaged cause when i turn the NSA off and on i can access it, read/write data without any issues.
Would be awesome if someone has an advice how to fully reset it.0 -
To remove the volume you basically only need to wipe the partition table of the disks and reboot.
If the Telnet backdoor works for you you can executedd if=/dev/zero of=/dev/sda bs=16M count=1<br>dd if=/dev/zero of=/dev/sdb bs=16M count=1<br>reboot<br>
This will overwrite the first 16MB of both disks, and reboot then. After reboot the disks will be treated as new.1 -
Will try, thanks a lot!0
- 588 USG FLEX H Series
- 477 News and Release
