Zyxel Multy X - Country Code
Joakim
I bought my 2 pack Multy X in Norway and when checking the 802.11d Country Code it gives me CH.
I live in NO country code and the frequencies are different here.
Can you please explain why the router does does not setup with the NO Country Code?
I am missing 104, 108, 112, 116, 120, 124, 128, 132, 140 channels due to this.
Joakim
#MultyX_March
Joakim
#MultyX_March
All Multy X devices used in EU, the country code is CH.When you have installed more than two Multy X devices, your wireless client only can see channel 36, 40, 44, 48. Channel 104, 108, 112, 116, 120, 124, 128, 132, 140 is using for wireless dedicated backhaul.If you have installed only one Multy X device, your wireless client can see 36, 40, 44, 48, 104, 108, 112, 116, 120, 124, 128, 132, 140. Because only one Multy X device, it does not required wireless dedicated backhaul.1
May I know how do you check it? Which command did you enter?- When checking the 802.11d Country Code it gives me CH.- I am missing 104, 108, 112, 116, 120, 124, 128, 132, 140 channels due to this.0
Macbook. Hold down the option button and choose the network symbol on the top. It will provide info about Country Code, RSSI, BSSID among other things.0
Ok. Good answer.
Thanks.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
