vmg - parental control schedule schooldays different from weekend
cesarepaci
cesarepaci Posts: 1 image  Freshman Member
edited May 2019 in Smart Home Product
hi, i have a problem with the parental control time scheduling of my ZYXEL VMG8823. For some my kids devices only,  I want to setup a parental control schedule for working days and anotherone for weekend days, but apparently one clash with the other
#CPE_March
  • AAAAL
    AAAAL Posts: 125 image  Ally Member
    edited March 2018
    Hi cesarepaci,
    You can create two parental control profile for your VMG8823, one for working days and the other for weekend days. VNG8823 support a maximum of 20 profile parental control.
    Try to use this in : security -> Parental Control -> Add New PCP
    PCP can define the internet access day and also the authorized access time.
    Hope this information would help you.
  • NVV
    NVV Posts: 1
    I want to do the same thing but when I set up the 2 profiles as described, I get NO access on weekends. It is as though the first profile is the only one that is in effect and signifies no access on weekends. I am using a Zyxel VMG4825-B10A.
    Has the method described been tested by Zyxel?  Any other suggestions?
  • SEJ
    SEJ Posts: 112 image  Ally Member
    Hi NVV
    Not sure how you set the PCP.
    If you set the 2nd profile as Saturday and Sunday 00:00~24:00 as the previous post, it means the internet will be blocked during the whole weekend.
    If you need no restriction during weekend, you may just remove the 2nd profile.
