New firmware - Any changes to how many nodes supported?
Joakim
Thanks for a great update on the FW and App.
Is there any change for how many Multy X nodes that are supported? I would like to use 4.
#MultyX_March
#MultyX_March
Primary Multy --> Second MultyPrimary Multy --> Third Multy --> Fourth MultyYes, it can be hybrid Star/Daisy chain.0
With Daisy Chain, it can support maximum 3 hops, 4 nodes. But the performance will be declined very much with more hops.For example:Multy X Node_1 ))) Hop1 ((( Multy X Node_2 ))) Hop 2 ((( Multy X Node_3 ))) Hop 3 ((( Multy X Node_40
Thanks.
My setup would be hybrid star/Daisy chain.
Meaning:
Does this setup make sense?
@Joakim,
If these 4 Multy evenly covers your whole space and they are in moderate distance between each other, It should work fine. End devices near 1st/2nd/3rd would work great, only rest near 4th would have little speed drop due to more hops. You can do some speedtest with your setup.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 496 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
