[NEBULA] dual Wan Failover
@techlogic
At this stage, the default designed for WAN1 and WAN2 are active, and they will share traffic loading. When you enable both WAN on NSG. Then when WAN1 goes down (cable unplugged), all traffic will be switched to WAN2, and when WAN1 is recovered (cable plugged), all traffics will be shared with both WAN.
The failover mechanism is that you can configure active or passive mode for WAN1 and WAN2. You enabled both WAN on gateway, and set WAN1 is active and WAN2 is passive, then when WAN1 (primary) goes down (cable unplugged), all traffic will be switched to WAN2 (back up), and when WAN1 is recovered (cable plugged), all traffics will be switched back to WAN1. Is it what you want?
Where are the active and passive mode settings found? I can't see them anywhere.
Hi @TCL_Support
Welcome to Nebula Forum.
Currently, the mechanism of WAN failover is still under developing. Let's look forward to see it on NSG.
Hi @TCL_Support
There is a clear description of our mechanism on NSG for you,
At this stage, NSG can only detect physical down, so when you enable both WAN, and then when WAN1 goes down (cable unplugged), all traffic will be switched to WAN2, and when WAN1 is recovered (cable plugged), all traffics will be shared with both WAN.
In the future, the failover mechanism on NSG will be that WAN1 and WAN2 are still run on Active mode, and NSG can detect Internet circuit down (circuit disturbance, ISP breakdown…etc). So when you enable both WAN, and then when WAN1 Internet circuit downs, all traffic will be switched to WAN2, and when WAN1 is recovered, all traffics will be shared with both WAN.
If you would like to see the mechanism of Active/Passive mode, I would like to help you submit feature request in the idea section.
Hi Someone who need Active/Passive mode,
At this stage, Active/Passive mode is not available on NSG, and if any assist needed, please PM @Nebula_Chris for this request.
Hi, it's possible to know when Active/Passive mode will be available?0
Hello!! @skara
This feature is in our roadmap, however the schedule is still under discussion.
If any assist needed, please PM me.
Hi, I have the same problem. I thought it could be solved by using the policy route as mentioned in this post https://businessforum.zyxel.com/discussion/1488/how-to-configure-policy-route-on-nsg
but all internet traffic is being switched between WAN1 and WAN2 even with the policy route applied.0 -
Hello @Link
Could you please reboot your device, it's seems like you have encounter the routing issue that we plan to fix on December, let me know if the issue persist.
/Chris0 -
Hi @LinkI have learned from my colleague that the root cause is because the mis-configuration, after change the destinaion from "0.0.0.0" to "any" in policy route have resovle your issue.Good to know of it!
- 588 USG FLEX H Series
- 476 News and Release
