325 V2 Security Certificate
TicFan
TicFan Posts: 2 image  Freshman Member
edited April 2018 in Personal Cloud Storage
Hi
I'm looking for some step by step assistance.
When I try to login to my 325 V2 status page using Chrome I get a message saying my connection isn't safe. How do I go about fixing this?
I know it is something to do with my security certificate but I don't know what to do about it.
Many thanks
#NAS_April
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    Are you use HTTPS to access your NSA325 v2?
    If yes that as I know chrome and firefox had change the mechanism to use SSL, the certificate should be signed by third certificate Authority, so NSA325 v2 has to create a self sign and provide it to third certificate Authority (charge money), then after return, import the ceritificate back to NSA325 v2.
    But if you need more detail information for the certificate, I don't have the experience to have the certificate, maybe someone can provide you the information.
