nsa325 v1 ipv6 dn/ip filter
florinaalex
Allocated ipv6 to nsa325.
Now in the NFS share, as a required field need to input a DN/IP filter.
How do I add a value, which would be accepted by the nfs?
#NAS_April
#NAS_April
I try it with my NAS, but the format with ":" is showed incorrect in DN/IP textbox, so I thinkthe NFS pacakge is not supported IPv6.
You may need use IPv4 with NSA325 v1 and other client.0 -
Hi Ijnrsi,
Thank you for your reply.
I have edited the /etc/exports file as well, in the GUI no mount has been shown. I think currently the NFS package is for version 3. An update to NFSv4 would probably solve the problem.
CIFS mount is just fine with IPv6. It would make the NSA325 functionality consistent.
It's great to hear the way to make it work.
But NSA325 v1 is old product for Zyxel and no update since 2016/6, so I think there is not possible to have the new package.0
- 441 Beta Program
- 292 Service & License
