Does the Multi X support different DHCP scopes and static routes
bydandie
bydandie Posts: 2 image  Freshman Member
edited May 2018 in Multy WiFi System
As above, I need a system that supports custom DHCP scopes and static routes.  Does Multy X do this?  If not, then I'll be sending it back as the Velop does.
#MultyX_May
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    Currently, Multy X doesn't support custom DHCP scopes and static routes.
    I have moved this post to Ideas Discussions. We will evaluate these features and thanks for your feature request in Multy X.
  • bydandie
    That is a real shame, I shall have to send this back and keep the Velop then :(
