Multy extension
Hausi
Put the Zxycel multy in operation today. I'm very happy. Easy setup, running. Only I have a problem: in some rooms I need a LAN connection, the Zxycel multy is not nearby. Is there a WLAN adapter with LAN connection that works with the multy? Similar to Devolo?
#MultyX_May
> Is there a WLAN adapter with LAN connection that works with the multy? Similar to Devolo?Not sure what do you mean, is it a powerline device or ...?Can you explain more detail what is your needs?0
I need a LAN connection in one of my children's children's rooms. The WLAN is enough for iphone and ipad but other devices need LAN. This I wanted to enable my third Zxycel.
Multy X is not supported wireless client mode.You need a Wireless Extender to connect your LAN devices.For your reference:https://www.zyxel.com/products_services/home-wireless_extenders.shtml?t=cExample topology:Internet---<WAN>---1st Multy X)))<WLAN>(((2nd Multy X)))<WLAN>(((Wireless Extender---<LAN>---LAN Device0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
