IP Range & Share Device With Guest Network
brettIT
I am thinking about changing from Google WiFi to the Multy X system.
Can you change the IP range and also can you share a printer with the guest network (this part is very handy when you have a guest staying for a few weeks but don't want them on your main network).
#Multy_May
#Multy_May
Multy X is supported Guest WiFi.
But Multy X doesn't support custom IP Range currently.Thanks for your feature request in Multy X and we will evaluate it.0 -
Thanks for the information about the IP range. The question I had about the guest network was can I share a printer that is on the main network to also be on the guest network?0
The main network segment of Multy X is 192.168.212.X and the guest network segment of Multy X is 192.168.141.X, they cannot communicate each other.0
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
