Zyxel NAS 540 with Seagate İronWolf 8GB
sinirli
I recently purchased the NAS 540 to use it with my Seagate Ironwolf 8GB (ST8000VN0022) but the disk physically does not fit into the yellow plastic in the NAS.
There are 2 small nubs on the plastic that just don't have anywhere to go in the disk.
Is there a solution for this? Other than changing the NAS or disk I mean..
#NAS_May0
The only way I think is cut it out....Or you can put something under the HDD in the slot to make the HDD be possible to plug into the SATA interface, but this is really not a good option..0
Thanks Ijnrsi, I think I will just buy another disk and sell this one
- 588 USG FLEX H Series
- 477 News and Release
