Upgrade to 5.13 from 5.11 VMG1312-B10D
I'm trying to upgrade from 5.11 to 5.13 and all that occurs is the router rebooting but no upgrade. When I try again, a message pops up saying illegal Image and then seems to disconnect the router from the internet, leaving only the Power LED green. I then have to force a reboot.
Any help would be appreciated
#CPE_February
Can you share both full file name of the firmware version? If you saw "illegal Image", you might use different firmware version. For example, the firmware I can see on ZyXEL website is 5.13(AAXA.7)C0. Maybe you had different one?0
just saw this now. the image i had/have is from Zyxel's website. There is a 5.11(AAXA.4)C0.zip file as well as 5.13(AAXA.7)C0.zip. I am currently on 5.11(AAXA.3)C0 so it's possible I have to upgrade in steps instead of the big jump.
I'll testing this out tonight0 -
Hi Speed59,
I can upgrade FW from 5.11(AAXA.4)C0 to 5.13(AAXA.7)C0 via GUI Firmware Upgrade page without problem. Below is the screenshot from my VMG1312-B10D. Is this the same with yours ? After I click the upload button, VMG will start firmware upgrade process and auto reboot. I successfully upgrade firmware without problem, could you share your fail screenshot for us ?
AS you can see from my screenshot, my current version is V5.11(AAZX.3)C0 so I'm wondering if 5.11(AAXA.4)C0 to 5.13(AAXA.7)C0 will even work due to the difference in the lettering of the FW versions. When I do try to upload the *.bin file, I get an error regarding an "Illegal image" then the router reboots but doesn't come back fully to where I then have to turn off/on.
Hi Speed59,
V5.11(AAZX.3)C0 is a customized version for your service provider so it’s impossible to upgrade to AAXA version on your device. If you need newer version, please find customer support contact information of your ISP and they’ll be happy to help.
- 435 Beta Program
- 176 Nebula Ideas
- 424 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
