dyndns on Multy X
Freddyg
I have just set up my new Multy X and have fantastic wifi all over my home now. Great!
However, I am trying to configure some of my devices to allow me to access them remotely. Can you tell me how to add my dyndns settings?
Many thanks.
#MultyX_June
Many thanks.
#MultyX_June
I think I have now solved the DDNS problem, I configured the NAS to use dynsns rather than the router. Set up port forwarding on the router too.0
Hi Freddyg,
Can you share what kind of problem you encountered? Any detail description?I used a free DDNS service to map my Multy X (also created the port forward rule) to access my ZYXEL NAS from outside and it works.
My topology:Internet---Multy X---NAS0 -
Hi.
I have now solved the DDNS problem, I configured the NAS use dynsns instead of the router (as with my previous configuration).
Thank you for your input
- 588 USG FLEX H Series
- 477 News and Release
