Will a WEB Interface come for Multy X?
Cellak
Cellak Posts: 1 image  Freshman Member
edited June 2018 in Multy WiFi System
#MultyX_June
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    Currently, we don't have plan to implement a WEB Interface on Multy X.
    You can use Multy APP to configure your Multy X.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Really? So the AP is delivered with some build-in aging?
    I have an ancient Apple Airport Express. The hardware is fantastic, it's the first AP I ever saw which is beautiful at the inside, and it's still working.
    But maintenance is a pain. To access the setup you either need an ancient Apple PC, or install some 200MB AirPort Admin Utility on an ancient Windows PC. (Doesn't run on anything later than windows XP, and isn't available for download anymore). It was never possible to setup it from a Linux PC.
    If Apple would have supplied a web interface,  the AP still would be usable. Now it isn't.
    I don't think it's a good idea to invest in a piece of hardware which needs proprietary software to maintain it.
    If ZyXEL ever revokes the app from the Apple or Google stores, you can bin the Multy X. And so far it's not clear to me if the App will work if ZyXEL shuts down their server.
