Ssid not showing
Vandennis95
My zyxel VMG8324-B10 switchs on alright buh nothing works I've tried several times to reset it buh nothing works...ive used the de reset method still nothing shows on my laptop or phone pls help?????
#CPE_June
#CPE_June
Hi Vandennis95,
May I know your firmware version, is it 1.00(AAKL.24)C0 or other ? Have you check the Wireless is enable in your VMG or not ? Or maybe you have hidden your SSID before ? You can confirm this in GUI Network Setting -> Wireless page.
Yea I've hide it before....1.00 dats my firmware version..The problem is why can't I reset it to erase all settings to start afresh
But now when I on it I can't see the ssid and de reset method still not working0 -
How do I check if my Wi-Fi is enabled0
Hi Vandennis95,
Could you provide your firmware version for me first ? You can check your firmware version via the GUI path : Maintenance -> Firmware Upgrade -> Current Firmware Version
If it’s possible, please provide your screenshot for the page : Network Setting -> Wireless -> General
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
