NAS326 recycle bin and change port
mashlamashki
Hello, I can not see the NAS326 recycle bin folder with other folders. Until now I had a model of the NAS320 and it was very easy because it was in the list of other folders. Please help if I can see the NAS326 model.
I have another question how can I change an external access port other than 8082?
#NAS_July
What do you mean of you can't see recycle bin with other folder?
Do you enable the recycle bin with those folder?
For external access, not sure what the way you used for external accessing, but if you use myzxyelcloud, then you can modify the UPnP setting as below, then you can be able able to access with the port what you want.
Or
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
