My Router Causes Lag Spikes Which Last For Minutes
KolibaR
My wifi signal booster sometimes causes lag spikes for minutes. For instance think as if i am playing an online game. My ping is 45-50, playing without any problem. Then suddenly something happens and my ping goes up to +1000 for like 3-4 minutes. Meantime, I literally can not post a single text from internet. I can not even open a site. It kills my internet for minutes. Happens several times in one hour time period. And in the exact moment I disable my router with Mac Filter, internet goes back to the normal. So I am %100 sure that router causes the problem. I need some help and sorry due to my english. I hope I made my self clear about my problem.
#Router_July
#Router_July
Hi KolibaR,
Can you share the model name of your router and firmware version?0 -
Hey,
model is NBG-418N v2, firmware version is V1.00(AARP.8) C00 -
Is possible to provide below information? I'll try to duplicate it in my side.- How often will it happen this problem? Only happen during playing an online game?- May I know your network topology?- Which system operation mode is running on NBG418Nv2? (Router/AP/UR/Client)- If NBG418Nv2 is router mode, what is WAN connection type you used?- Which IP address/Domain you ping?- When this problem happens, if you use Ethernet cable to connect your client and NBG418Nv2, does it still cannot access Internet?- What do you mean "And in the exact moment I disable my router with Mac Filter, internet goes back to the normal."? Are you activated MAC Filter on NBG418Nv2? May I know your usage?BTW, the latest firmware is V1.00(AARP.9)C0.0
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
