Multy X Iphone App
Supralux
The App on my Iphone shows not the same things, as the App on a Android Handy.
First:
I cannot test the WiFi-Signal. It shows the report: Please connect this mobile device to the wifi of a Multy X.
Second:
On the front of the App I also cannot see how many devices are are connected.
#MultyX_July
First:
Second:
#MultyX_July
Hi Supralux,
The App on my Iphone shows not the same things, as the App on a Android Handy.→ What do you mean about this? Do you mean Multy APP show different things between iPhones, or differen things between iOS and Android? Can you share more detail information?First:I cannot test the WiFi-Signal. It shows the report: Please connect this mobile device to the wifi of a Multy X.→ If you wants to test WiFi Signal via Multy APP, you need to connect Multy X WiFi first. What kind of problem that you encountered?Second:On the front of the App I also cannot see how many devices are are connected.→ Do you mean below screenshot? What is your Multy APP version and mobile device name/O.S. version? Is possible to provide the screenshot?
Thanks for your answer. The Problem is solved since our IT-Contractor used the wrong mode.
He put the Multy X in a Bridge mode insteed of the NAT-Mode.1
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
