Router AMG1202, cannot see router admin at 192.168.1.1
Perhaps I need to connect via ethernet? (didn't have an ethernet cable with me at the time; will try again on Wednesday.)
Question2. The reason I want to look at the router is that it's refusing to give an IP adress to a Canon wifi printer. Printer can see the SSID, authentication is set to WPA2-PSK but all the addresses are blank (this on Canon network confiuration page);
Question3. Cannot activate WPS on the router. When I press the WPS button (it looks like a key on the front of the AMG1202, I cannot get it to flash the WPS light, no matter how long I press the key for). I haven't tried a router restart (unlikely to make any difference I would have thought?) but the router was in use at the time.... Will try again on Wednesday. Cheers.
#CPE_July
Hi routerab,
You can try the following methods :
A1: You can connect to your AMG1202 LAN side and use the DHCP mode to get your gateway IP address.
A2: Have you tried to set your wifi printer with the static IP address ? Will it success or not ?
A3: You can download AMG1202-T10B user guide via the link : https://www.zyxel.com/support/SupportLandingSR.shtml?c=gb&l=en&kbid=M-01434&md=AMG1202-T10B#searchZyxelTab2 It has a careful description of the WPS mechanism.
Hi routerab,
Hi routerab,
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
