NAS 540 Volume gone after latest update.
Backup is running as we speak
As for Plex i've been trying to get it on my NAS but sadly I can't install the repository.
I've added it to the correct folder, renamed it,... I did everything as described in the other post but it won't show up in the apps after refreshing them...0 -
I had to search for 'the other post'. The method described there doesn't work, or it somehow triggers an installer in the firmware I'm not aware of.The instructions are written here.Downloading the web_prefix file has proven to be more robust than trying to create it yourself.0
Sorry I didn't link it, it was a couple of posts next to this one.
I just tried your method but this also doesn't add the repository into the GUI./i-data/4ebe74b4/admin/zy-pkgs $ ls
web_prefix.txt
The text-file should be in the correct place or am I wrong?
EDIT:
Also tried your file with .dms extension, same result.
No .txt. Just web_prefix
Great! it's installing now
thanks!0 -
Back to the previous topic... My NAS just started beeping. Checked the GUI and it's degraded again.
When I check the disks, they're all green and healthy.
Anything I can check?0 -
If you haven't rebooted it yet, you can look in the kernel log to see what happened.
dmesg<br>
Something particular to look for? It's a huge list.0
It has timestamps in seconds. Using 'uptime' you can query the current uptime. If you know what time it started beeping, you can calculate around which timestamp that happened.
And no, I don't know what you are searching for. Something diverging. But I understand that can be hard to recognize.
I guess seeing this that Disk1 is toast?
~ # dmesg | grep sda
[35635.818167] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35635.824554] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35635.847153] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35635.851718] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[35635.859031] end_request: I/O error, dev sda, sector 0
[35636.311040] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35636.317449] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35636.340097] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35636.344661] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 e8 e0 88 00 00 00 08 00
[35636.351972] end_request: I/O error, dev sda, sector 3907028992
[35636.772599] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35636.779017] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35636.801697] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35636.806293] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 e8 e0 88 a0 00 00 08 00
[35636.813600] end_request: I/O error, dev sda, sector 3907029152
[35637.308175] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35637.314604] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35637.337257] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35637.341821] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[35637.349142] end_request: I/O error, dev sda, sector 0
[35637.827690] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35637.834196] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35637.856984] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35637.861548] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 08 00 00 08 00
[35637.868878] end_request: I/O error, dev sda, sector 8
[35638.438347] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35638.444826] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35638.467858] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35638.472568] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 07 80 00 00 08 00
[35638.479966] end_request: I/O error, dev sda, sector 3999616
[35638.972655] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35638.979175] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35639.001991] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35639.006580] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 07 f0 00 00 08 00
[35639.013979] end_request: I/O error, dev sda, sector 3999728
[35639.502586] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35639.509109] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35639.532164] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35639.536748] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 08 00 00 00 08 00
[35639.544058] end_request: I/O error, dev sda, sector 2048
[35640.050899] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35640.057301] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35640.079978] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35640.084543] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 08 08 00 00 08 00
[35640.091852] end_request: I/O error, dev sda, sector 2056
[35640.547108] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35640.553495] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35640.576294] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35640.580859] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 0f 80 00 00 08 00
[35640.588186] end_request: I/O error, dev sda, sector 7999360
[35641.117850] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35641.124239] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35641.146953] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35641.151518] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 0f f0 00 00 08 00
[35641.158836] end_request: I/O error, dev sda, sector 7999472
[35641.639136] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35641.645645] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35641.668483] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35641.673071] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 08 00 00 00 08 00
[35641.680439] end_request: I/O error, dev sda, sector 3999744
[35642.148120] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35642.154506] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35642.177112] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35642.181687] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 08 08 00 00 08 00
[35642.189063] end_request: I/O error, dev sda, sector 3999752
[35642.753512] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35642.759941] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35642.782595] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35642.787189] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 e8 e0 87 80 00 00 08 00
[35642.794490] end_request: I/O error, dev sda, sector 3907028864
[35643.245022] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35643.251442] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35643.274076] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35643.278654] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 e8 e0 87 f0 00 00 08 00
[35643.285950] end_request: I/O error, dev sda, sector 3907028976
[35643.737364] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35643.743752] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35643.766419] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35643.770983] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 10 00 00 00 08 00
[35643.778289] end_request: I/O error, dev sda, sector 7999488
[35644.219719] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35644.226141] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35644.248797] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35644.253372] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 10 08 00 00 08 00
[35644.260762] end_request: I/O error, dev sda, sector 7999496
[35645.023232] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35645.029639] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35645.052257] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35645.056841] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[35645.064266] end_request: I/O error, dev sda, sector 0
[35645.523905] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35645.530409] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35645.553392] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35645.558022] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 08 00 00 00 08 00
[35645.565321] end_request: I/O error, dev sda, sector 2048
[35646.063478] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35646.069988] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35646.092804] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35646.097381] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 08 00 00 00 08 00
[35646.104709] end_request: I/O error, dev sda, sector 3999744
[35646.599118] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35646.605512] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35646.628244] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35646.632855] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 10 00 00 00 08 00
[35646.640172] end_request: I/O error, dev sda, sector 7999488
[35647.153386] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35647.159794] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35647.182386] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35647.186990] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[35647.194300] end_request: I/O error, dev sda, sector 0
[35647.606828] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35647.613348] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35647.636400] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35647.640970] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 08 00 00 00 08 00
[35647.648273] end_request: I/O error, dev sda, sector 2048
[35648.079480] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35648.085871] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35648.109373] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35648.114113] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 08 00 00 00 08 00
[35648.121641] end_request: I/O error, dev sda, sector 3999744
[35648.596529] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35648.603031] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35648.625617] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35648.630263] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 10 00 00 00 08 00
[35648.637572] end_request: I/O error, dev sda, sector 7999488
[35649.110468] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35649.116959] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35649.139650] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35649.144215] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[35649.151517] end_request: I/O error, dev sda, sector 0
[35649.600003] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35649.606425] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35649.629162] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35649.633726] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 08 00 00 00 08 00
[35649.641102] end_request: I/O error, dev sda, sector 2048
[35650.097011] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35650.103412] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35650.126127] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35650.130709] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 3d 08 00 00 00 08 00
[35650.138052] end_request: I/O error, dev sda, sector 3999744
[35650.583668] sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
[35650.590079] sd 0:0:0:0: [sda] Sense Key : 0xb [current] [descriptor]
[35650.613480] sd 0:0:0:0: [sda] ASC=0x0 ASCQ=0x0
[35650.618503] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 7a 10 00 00 00 08 00
[35650.626055] end_request: I/O error, dev sda, sector 7999488
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
