Multy X location
Dzygadlo123_
Just how important is it for each multy x to be the proper distance apart?
I have 3 nodes, 2 are a perfect distance from each other but one says move farther away but Ive just got nowhere else to put it.
By keeping it in same location, will this result in poorer performance?
#MultyX_Aug
#MultyX_Aug
What is the distance between your nodes?
You can use Multy APP "Diagnose" feature to test speed. If the result is good, you may skip the message. It is recommended message that move farther away. May I know do you meet the problem during usage?
- 588 USG FLEX H Series
- 476 News and Release
