My zyxel powerline won't link
Antarctica
Around two years ago I purchased three power line adapters to my house. They have all worked fine up until yesterday.
Now all of a sudden since yesterday, one of them refuses to link with the others. There was a short downtime on my internet conection yesterday, and since then it won't link anymore. I tried resetting and unplugging it. I even tried to switch between sockets but without success. The other two connects nomater what, but not the last one.
What do I do?
#PLA_Aug
#PLA_Aug
After you reset the device, can it re-pair/sync to other PLA by pressing encrypt button? What is the LED status of homplug?
If no light and no connect to other PLA, then I guess the device broke and you should contact Zyxel or you need a new one to swap it.
The middle led, which is the link status as far as I understand is just dead. It blinks red two or three times when I reset the device, otherwise just dead.
When I try to tell no by pressing the encrypt button the power-LED just starts blinking.0 -
So after blinking, did the PLA sync to other PLA? And possible to surf internet through the PLA to each other?0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 461 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
