WRE2205
SW1973
After I have uploaded firmware I cannot come in contact with the unit what can I do?
#Repeater_Aug
Wireless LAN adapter Wi-Fi:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : webspeed.dk
Ethernet adapter Bluetooth-netværksforbindelse:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
C:\Users\sweir>ipconfig
Windows IP Configuration
Wireless LAN adapter LAN-forbindelse* 2:
Ethernet adapter Ethernet:
Link-local IPv6 Address . . . . . : fe80::bcd1:6d5:724b:9c8c%3
Autoconfiguration IPv4 Address. . : 169.254.156.140
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Link-local IPv6 Address . . . . . : fe80::577:fb2:251a:ee70%7
IPv4 Address. . . . . . . . . . . : 192.168.0.33
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:184c:a94:3f57:ffde
Link-local IPv6 Address . . . . . : fe80::184c:a94:3f57:ffde%14
Default Gateway . . . . . . . . . : ::
C:\Users\sweir>
IPv6-DNS-servere: fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Producent: Intel Corporation
Beskrivelse: Intel(R) 82579LM Gigabit Network Connection
Driverversion: 12.15.22.6
Fysisk adresse (MAC): F0-92-1C-5D-14-7B
WRE2205
Firmware
WRE2205 v2
V1.00(AANK.5)C0_20171101(KRACK_hotfix)
November 21, 2017
Server 1
#Repeater_Aug
May I know did you try hardware reset button? It is the same WPS button, then you can press it and hold the button, after 10 seconds, the power LED will begin flashing, then you can release the button.
Moreover, please follow the steps to configure it.
- Reset the WRE2205 via pressing WPS button. Here is the link from Youtube to show you how to reset the device by other user: https://www.youtube.com/watch?v=wTShS-2eGCI
- After reset done, connect your PC/NB to WRE2205’s Ethernet port via wired.
- Check your network interface card receive the IP address, please refer the attachment: Network Interface card.png.
- Then you can use IP 192.168.1.2 to access WRE2205 web management page, here is the record for you: https://youtu.be/t3L9yZu9KxE
I have performed all the issues you have right but it not possible to get in contact with the unit after the frame where was uploaded.FirmwareWRE2205 v2V1.00(AANK.5)C0_20171101(KRACK_hotfix)November 21, 2017Server 10
what is your wireless IP address and Ethernet IP address?
After reset, the IP address should be reserved from WRE2205 v2 as 192.168.1.X, then you can be able to login via 192.168.1.2.
What is your LED status?
Make sure you have reset the device successfully, press key(WPS) button 10 seconds, then power LED off and on, then replease the button to reset and reboot.
- 603 USG FLEX H Series
- 481 News and Release
