distance between units MULTY X
kulekurt
What happends if the distance between units MULTY X are less than 10m, cause if 8m isn´t enough I have to have one outside my house.
#MultyX_Aug
#MultyX_Aug
You can tap the extender icon on Multy App home page to check "WiFi Backhaul" signal strength. Also, you can use Multy App "Diagnose" feature to test the speed. If the result is good, you may skip the message. It is recommended message that move farther away.
May I know do you encountered the problem during usage?0
May I know do you encountered the problem during usage?0 -
Thank you for the help.1
- 588 USG FLEX H Series
- 477 News and Release
