Cannot access 192.168.1.1
Valentin
Valentin Posts: 2 image  Freshman Member
edited September 2018 in Smart Home Product
I have an old Zyxel modem (P-660RU-Tx series) and the instruction guide says to key in "admin" as username and "1234" as default password. I tried that but cannot. Has the default password changed? How to I access http://192.168.1.1? Please help. Thanks.
#CPE_Sep
  • Valentin
    I tried to get direct support from Zyxel but nobody answered.
  • Corrco
    Corrco Posts: 3 image  Freshman Member
    Hello Valentin. Firstly from the device you are using to try and connect to your Zyxel router can you ping 192.168.1.1? What IP address does your device show you are assigned?
  • AAAAL
    AAAAL Posts: 125 image  Ally Member
    Hi Valentin,
    What’s your firmware version? Have you lost your admin password or just cannot find your default gateway in the router?
    How about trying this: open the computer command window -> input “ipconfig” -> find the default gateway IP address to look is that 192.168.1.1 or other -> ping the gateway IP address -> will we get the reply packet or not?
