AMG1001-T Is it ok for the modem not to have an IP connection?
leonleon
The Internet LED indicator has the status off, but I have an internet connection. What does this mean? Is it ok for the modem not to have an IP connection?
#CPE_Sep
#CPE_Sep
Are you on wifi? Are you sure you are using your own network?
A router which has no outside IP cannot give you access to the internet.
Hi leonleon,
May I know what’s your LED indicator? Is it in red or green or other?
You can check your connection states to see if the router have the IP address or not first.
Login into the GUI -> States -> Devices Information -> WAN IP address
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
