Network topology button in Settings >> Advanced Setting of Multy X app 2.0.2
phoner123
phoner123 Posts: 9 image  Freshman Member
edited September 2018 in Multy WiFi System
Hi - in the UK version of the app is the Network Topolgy button meant to do anything? I had hoped that once you pressed it you would see your network topology but nothing seems to happen. Should this be happening?
#MultyX_Sep
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    @phoner123,
    The button is re-locate feature when you have more than two nodes.
    It means when you press the button, system will re-locate all nodes. Such as 3rd node need connect 1st node directly or connect 2nd node would be better.
