Zyxel VMG4825-B10A modem will not connect to internet after power loss
Matawanakee
My two neighbors and I are all having the same problem. When the power goes out the modem turns on but does not connect to the internet. It takes up to three hard restarts to get it to connect. Is there a solution.
#CPE_Sep
#CPE_Sep
Hi Matawanakee
What is the firmware version on your modem?
You may try the latest firmware version to see this problem still exist or not.
If your modem came from your ISP, you might need to check with your ISP for the latest firmware version.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
