NSA310 TDC to standard firmware
Alexey2008
Hello.
I bought an NSA310 TDC Homedisk. I want to install the standard firmware NSA310 on it.
The site nas-central.org does not open. Where can I get the files for the procedure of changing the firmware to the stock?
#NAS_Oct_2018
@Alexey2008 : How are your scripting skills? The needed universal_usb_key_func.zip is archived by archive.org. Search this forum, somewhere I put a download link.
I do not have the force_flash anymore, but I still have the original flashing script. It needs to be adapted a bit (pull the device check, do something with filenames, redirect output to logfile). At the moment I have no time for that.
Do you check with TDC?
I think they should have the way to help user to change the TDC device to standard version.0 -
Good afternoon! Thank you very much for the answer. I have already figured out). Three days of study) Now installed stock version. I changed the identifier and flashed it through nsa310_recovery_usb.1 -
@Alexey2008
Can you tell me how you did. I must also put an original zyxel firmware on tds nsa310. Thanks0 -
do enyone have the force_flash.zip0
does anyone cand write the steps to do that?0
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
