NAS 326 the directory disappeared
PALI75
I have a query, my own NAS326, ours started beeping (disk error) in the settings I gave to fix, after repairing it disappeared my directory created, the other directories remained with the data
#NAS_Oct_2018
#NAS_Oct_2018
I've backed up the data, done everything you've done to me, but I still do not see my work directory :-(
I'm still unsuccessful, the data is backed up, I can not see my address book
What is the privilege you assigned to the shard folder?
Who can access the shard folder?
The folder seems like not belong to anyone, you should check admin has permission to login.0 -
the server reported a bad disk so I fixed it, everything corrected but disappeared the directory WORK I look into the rights
I'm logged in as admin
Can you show me the following page?
thank you for your advice, the directory was off reading and writing I can see it
Now you should be able to read your data.
Suggest you to create a backup on other place with all your data to keep it saving, because your HDD might has some problem.0 -
I copy the data, buy a new HDD
- 441 Beta Program
- 292 Service & License
