NAS 326 the directory disappeared
PALI75
PALI75 Posts: 6 image  Freshman Member
edited October 2018 in Personal Cloud Storage
I have a query, my own NAS326, ours started beeping (disk error) in the settings I gave to fix, after repairing it disappeared my directory created, the other directories remained with the data
#NAS_Oct_2018
  • Batou
    Batou Posts: 101 image  Ally Member
    @PALI75
    Do you check your privilege page for shared folder?
    Maybe they are disable and you need to un-check to enable the shared folder.
  • PALI75
    edited October 2018
    I've backed up the data, done everything you've done to me, but I still do not see my work directory :-(
    I'm still unsuccessful, the data is backed up, I can not see my address book
  • Batou
    What is the privilege you assigned to the shard folder?
    Who can access the shard folder?
    The folder seems like not belong to anyone, you should check admin has permission to login.
  • PALI75
    the server reported a bad disk so I fixed it, everything corrected but disappeared the directory WORK I look into the rights
  • PALI75
    I'm logged in as admin
  • Batou
    Can you show me the following page?
  • PALI75
    edited October 2018
    thank you for your advice, the directory was off reading and writing I can see it
  • Batou
    Now you should be able to read your data.
    Suggest you to create a backup on other place with all your data to keep it saving, because your HDD might has some problem.
  • PALI75
    edited October 2018
    I copy the data, buy a new HDD
