ZYXEL 326 unmounted shares
jan_filipec
jan_filipec Posts: 9  Freshman Member
edited October 2018 in Personal Cloud Storage
Hi, I was trying to mount a full hdd to my Zyxel 326 and when unmounting it, I accidentaly unmounted almost all the shares with umount -a. Now only admin and data shares work, the others I can not access and I also can not access the web gui, asi it always says my password is wrong. Anybody knows which partitions are mounted where by default so I can set it back?
Thanks a lot.
#NAS_Oct_2018
  • Mijzelf
    Mijzelf Posts: 2,933  Guru Member
    You can't mount them back, as you also unmounted some tmpfs filesystem, which are lost in cyberspace now. But you can simply reboot to get your mounts back.
  • Mijzelf
  • jan_filipec
    Oh wow, did not expect that to be that easy. Thanks a lot.
