entware on NSA320
canute
canute Posts: 9  Freshman Member
edited November 2018 in Personal Cloud Storage
I accidentally uninstalled Entware on my NSA320.
I'm not able to reinstall it through the Web Admin packages page (That page doesn't Retrieve any new list from internet nor does install change anything in /opt directory)
Does anyone know how to fix this?
#NAS_Oct_2018
  • Mijzelf
    Mijzelf Posts: 2,395
    250 Answers 1000 Comments Friend Collector Fifth Anniversary
    But when I try to install Entware(It completes to 100%), I don't see anything installed in /opt. That directory is still empty.
    Can you have a look at the logs in /usr/local/zy-pkgs/opt/var/log?
    Is there any way for me to install the Entware package from command line?
    Theoretically yes. You can follow the script in /usr/local/zy-pkgs/etc/init.d/Entware-ng. But it's not straightforward, and get it started on boot isn't simple either.
