NAS326 ports???
Nickvryn
Hi, noob here.
i bought a nas326 everything works fine unless the mycloud function can not find my device. It’s som UPnP port forwarding thingy. The problen is that i dont know which ports should I forward For this to work from 4g on my mobile.
#NAS_Oct_2018
Myzyxelcloud to find nas326 doesn't need to setup the forwarding rule, so if your nas326 can't be found in portal, then you have to check the package installed and router support UPnP or not.
Here you can refer the article is the check list.
https://homeforum.zyxel.com/discussion/comment/2829#Comment_2829
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
