NFS-protokol
zyxelist
Hallo,
how to run NSA325 v2 and nas540 with the NFS protocol? The two servers have no internet connection.
Many thanks for a answer!#NAS_Nov_2018
What do you mean?
I want use NFS -protocol. Its the network file system from sun. My computer dont find it on the server. Is ist possible to install it?
Ah, I see. Well, for the NAS540 that's no problem. You only have to enable NFS on the (webinterface-)desktop, and create one or more NFS shares. (You can't have the same share on both Samba and NFS).For the 325 it's a bit harder. You'll have to install the NFS package, which is hard without internet access.1
- 588 USG FLEX H Series
- 477 News and Release
