NFS-protokol
zyxelist
zyxelist Posts: 4 image  Freshman Member
edited November 2018 in Personal Cloud Storage
Hallo,
how to run NSA325 v2 and nas540 with the NFS protocol? The two servers have no internet connection.
Many thanks for a answer!
#NAS_Nov_2018
  • Mijzelf
    Mijzelf Posts: 3,063 image  Guru Member
    What do you mean?
  • zyxelist
    I want use NFS -protocol. Its the network file system from sun. My computer dont find it on the server. Is ist possible to install it?
  • Mijzelf
    Ah, I see. Well, for the NAS540 that's no problem. You only have to enable NFS on the (webinterface-)desktop, and create one or more NFS shares. (You can't have the same share on both Samba and NFS).
    For the 325 it's a bit harder. You'll have to install the NFS package, which is hard without internet access.
