Zyxel Multy AC3000
rickyprose
Dear all,
I'm planning to buy a Zyxel Multy AC3000.
The only part is holding me is the limited control features of the Mesh Router.
Basically right now you can only control by APP and not by web interface.
I would like to ask if in the future the Zyxel team will support more features by APP or maybe they will enable WEB interface with more control over the router such as parental control, ethernet backhaul etc etc..
I see the chipset used is the qualcomm same as many others, then I don't think is a problem of H/W just the company policy support on the product.
I would like to know if any plan for future features support.
Thanks in advance
Rickyprose
#MultyX_Nov_2018
Thanks in advance
Rickyprose
#MultyX_Nov_2018
@rickyprose,
Thank you for your interest in Multy X.
We will keep improving Multy X for the better user experience.
Multy X only allows to use Multy App to manage it.
And it has parental control feature.
https://homeforum.zyxel.com/discussion/196/how-to-set-up-the-parental-control-feature#latest
Currently, Ethernet backhaul is still under developing.
May I know which features you want to enhance?
BTW, we have another WiFi System - Multy Plus, it has supported web interface.
https://www.zyxel.com/products_services/AC3000-Tri-Band-WiFi-System-Multy-Plus/
- 602 USG FLEX H Series
- 480 News and Release
