can i connect 2 multy x hubs together using ethernet
gz00
I have an old house some parts dating from 1600s with metre thick stone walls. Wi-fi won't penetrate. Can I connect using ethernet?
#MultyX_Nov_2018
#MultyX_Nov_2018
Multy X seems still not ready to implement Ethernet backhaul.
I try to connect two Multy X nodes via Ethernet cable directly. It works, but not sure there is any issue about that. First, you need to setup Multy X to use wireless backhaul, then use Ethernet cable to connect two nodes directly.
Internet---<WAN Port>1st node<LAN Port>---<Any Port>2nd node
- 242 Nebula Ideas
- 6.8K Security
- 764 USG FLEX H Series
- 385 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
