Parent control
Haavard
Is it possible to limit parent control to maximum hours pr day?
#MultyX_Nov_2018
#MultyX_Nov_2018
Which product you inquired about parental control?
And what do you mean "limit parental control to maximum hours per day"?0 -
I want to limit the time my children are online pr day.
Can you share the model name of your ZYXEL product?0
Im using multy x.0
Below is Parental Control FAQ of Multy X for your reference.
https://homeforum.zyxel.com/discussion/196/how-to-set-up-the-parental-control-feature#latest
Select the device of your children and add it to the group.
The group can set the limitation schedule to access Internet.
May I know what kind of the problem you encountered on Parental Control setting?1 -
Thank you for your answer!
I am using this feature now, but this is fixed times. I would like to limit for 2 hours a day, and the children can choose what time they will use it.0 -
Thank your for the feature request. We will evaluate it.
Currently, Multy X is only supported the fixed times of parental control feature.1
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
