How to get to login page of my router through my Android phone
LORDFURYjww
Help please. .......
#Others_Nov_2018
#Others_Nov_2018
Hi LORDFURYjww,
Can you share your ZYXEL product model name and firmware version?0 -
Can you please share your Router details eg: Brand & model number
If you don't share then also I can help you through
most of the routers have their admin login homepage to this link
make sure you are connected to wifi while you try this admin login link.
then it will ask you for username & password
you can find the default username: password in the manual of the router or on the box of the router and also on the router itself.
If you couldn't find the username and password then you can search for the default username and password of your router (follow this article for that How to Put a Password on Wifi)
After login, you can my any changes to your wifi like changing SSID or password.
Thanks0 -
I have followed these Steps to enter 192.168.1.1 Login Panel.
- Type http://192.168.1.1 in any of your Browser Address bar. (Firefox, Google Chrome, Safari, IE).
- If the IP is Not Working, then 19216811 is not your Default Router IP Address.
- Once you found the Correct IP Address, Enter the Same IP Address into your Browser Address Bar.
- Next, a Pop-up Box appears asking you to Enter Router Username and Password.
- Then, Put down the Login details in the Web-Interface and you will be given Admin Access Immediately.
- Done, You have Successfully logged in to 192.168.1.1 Admin Page
- 3K Nebula
- 224 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 640 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 54 Wireless Ideas
- 303 Service & License
- 495 News and Release
- 93 Security Advisories
- 109 Security Highlight
