Migrate from NSA325v2 to NAS326
Rafael
Rafael Posts: 1 image  Freshman Member
edited December 2018 in Personal Cloud Storage
My NSA325v2 stops the network link after some minutes after power on. I consider to buy the NAS326.
May I just remove the two hard disks (mirrored) from 325v2 and insert them in NAS326?
Thanks.
#NAS_Dec_2018
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Unfortunately not. The disk layout has changed between firmware 4 (NSA series) and 5 (NAS series).
    Yet it is possible to migrate a raid1 volume. It boils down to use one of the disks to create a single disk raid1 volume on the 326. Then insert the 2nd disk. Login over ssh, assemble&mount the 2nd disk manually, and copy data over. (All in ssh).
    Finally add the 2nd disk to the volume.
