How to access .pgk folder on NAS540
SilentBob978
SilentBob978 Posts: 3 image  Freshman Member
edited December 2018 in Personal Cloud Storage
Hi there!
I'd like to swap out the updatemanager.py file on my NAS540 (Pyload isn't working properly in it's current state and cannot update) but can't access the folder. On my NSA325 a folder called zy-pkgs shows up in the explorer, but not on the NAS540. I read something about symlinks but have no idea how to use them... If anyone could help me I'd be very grateful!
#NAS_Dec_2018
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    The pkg directory on the '540 is in /i-data/sysvol/.PKG/
    I think WinSCP can open that directory for you.
  • Mijzelf
  • SilentBob978
    deleted...
  • SilentBob978
    I did swap out the UpdateManager.py file with the one that works on my NSA325, but now pyload tells me
    Fehler beim importieren von UpdateManager: No module named Hook
    (     error       importing           )
    The preinstalled UpdateManager.py gives me this error message
    ADDON UpdateManager: Unable to connect to the server to retrieve updates
    It was so easy on the NSA325.... shame on Zyxel...
